I'd like to replace my daughters battery in her '06 M3 before winter. It still has the factory original battery but I have never liked the cranking of this battery(new battery may not change this)but, I want to change it anyway. The original battery is the smaller of the two available and I want to use the larger more CA than the smaller for the same money at W*M
The battery sits inside of a battery box with a cover and an incomming air duct for cooling. I first thought this duct was for the "intake" but it's actually for the battery cooling.
The larger of the two batteries(that I'd like to install) will just fit in this battery box. I'm a bigger is better guy for no real reason but the larger battery does have more CCA/CA compared to the smaller battery(probably moot in this case!)
My real question is:
Because the larger battery will just fit in the box while still being able to cover the battery, will this cause any cooling issues in the warmer temp along with engine heat as the battery sit closer the the FireWall than the front headlight/grill? I don't want to defeat the purpose of getting the larger battery(which I'd prefer) if it's only going to die faster due to lack of cooling. The smaller battery fits inside the box where incomming air can surround the battery but, not so with the larger. Will I be defeating my purpose of getting the larger battery?
Cooler temps are approchaing and there will be no issue in that respect but we'll have just as many summers as winters so I want to do the right thing.
