If a pump screen is really clogged, I'd drop the oil pan. If I wanted to clean things up in an engine, MMO or Kreen.
What makes you "suspect" your screen is clogged? A clogged screen is serious and can wreck an engine in short order. I wouldn't mess with any additive if it were my car, I'd fix it the right way.
Sound when engine was revved sounded like a whistling, akin to a transmission with low fluid "Howl" that MAY have been coming from the top of the engine. A driver with a trained ear could likely identify how it sounded, not too obvious, but caused me concern.
I too look forward to dropping the pan. I know about the "Scrape with soft metal or plastic" rule.
Now, how do you get it to seal back into place correctly... Silicone? Gasket? How does it not leak after reinstall?
This is the sitting "Beater Probe," I am going to spend two or three full days with that thing, mechanic assisting in between jobs, if i can work out an arrangementr. Sometime next year, or the year after.
Hey, its something to do. And i learn a lot in the process.
Car like the beater i got, less "Sporty" and probably less "Beat on" in its 170,000-mile life...
2.5L DOHC V6, (Small V6!)
