My sister will be visiting this weekend, and I think she's due for an oil change on her 2005 Kia Spectra. I've changed the oil on it once before, I think, but IIRC that time I was someplace else and had ramps. I may end up wanting to rotate its tires too depending on how they look.
I don't know what the underside of the car looks like and I don't have a service manual. Does anyone have any input on the following?
1) Front and rear jacking points. I'm guessing there will be a sturdy cross member in front to use but I don't know what to expect on the rear.
2) Lug nut torque. If I can't find anything I'll just use my old standby of 80 ft*lbs.
3) Oil drain plug torque. OK, I realize this one's obsessive. If I can't find a spec I'll use my old standby of ~30 ft*lbs.
Like I said I'm mainly interested in jacking point info if anyone knows anything. This is the model that's based on the same year Hyundai Elantra, with the 2.0 Beta II engine IIRC.
