I was checking out US patents online and there seems to be a patent for a series of motor oils with radically different viscosities for high performence applications. These viscosities include 0w60 0w70 0w80 0w90 0w100 as well as some negative viscosity motor oils such as -5w40.
These oils seem to be a blend of light medium and heavy weight poly alpha olephins along with polymers of different weights. Theoretically such oils will allow engines to be designed to operate with higher RPM's and such oils will be able to take a greater load. A greater load will be good for truckers because they will be able to lug the engine to gain better fuel economy without destroying it. And of course the wide temperature range of the oil allows better fuel economy and instant lubrication at startup which is a feature tough to find in a high performance oil.
