Originally Posted By: [RT
ProjUltraZ]I have koni singles, ground control adj 4 corners, about 1" drop eibach linear 500 lb fronts 150 rear, and his 35/22 swaybars. ride is not as comfortable as stock but at 3,380 lbs it handles halfway between a stock camaro and a vette.
Same setup here, except I have 600 lb. in. fronts, 175 lb.in. rears, double adjustable front Konis, 3250 lbs. with a full tank (no driver).
I also have a Random Tech adjustable torque arm, and UMI double adjustable, chromoly, Roto-Joint ended lower control arms and Panhard Bar.
I am considering a Fays2 Watts Link, but I do not want to add the weight, even though it would handle even better yet.
Even on street tires it
really suprises, even SHOCKS almost all import nameplate drivers in the "twisties" which they feel are ONLY
their domain. (Even more so if I'm on sticky 100 treadwear rubber!!)
Some of the high-buck, high zoot, Euro import owners get quite visably upset (more like extremely P.O.ed!
) that an inexpensive 'mullet-mobile' can stay right with (or drop if I'm in front of them) their country club racers.(Them; "I paid $70K+ for this thing, how DARE his 'straight line ONLY' domestic [censored] keep up!"
