Originally Posted By: mechanicx
Can you get original Green? What does it typically run there?
Yes, but not easily. The only place I absolutely know I can find it without question is Partsource. They stock the Havoline/Texaco conventional. It's a buck or two cheaper per gallon than Dexcool and G-05. Canadian Tire might have some conventional in their house brand line, but their labels don't say a lot except for the specifications met, and without a cheat sheet, it's a mess to figure out. I wish Zerex Original Green was readily available up here.
Most parts stores just have various dexclones. NAPA Canada's parts list has about 20 different varieties and sizes of dexclones and diesel coolant.
Last time I was at Partsource, they only had one gallon of the Texaco, which is not nearly enough for a flush and fill of my F-150. Canadian Tire used to have the best selection of coolants, but it's a mess now. Walmart, at least on paper, could have the best selection, since they stock almost every major brand. Lately, though, I've only seen various dexclones and licenced DexCool (premixed and concentrate) and G-05 premix.
Just a few years ago, Esso used to have conventional green. What they have now is at
http://imperialoil.ca/Canada-English/Files/Products_Lubes/IOCAENCVLESEsso_coolant_antifreeze.pdf if you care to look. The non-HD coolant looks to be something like G-05, but I'd appreciate your view on that.
Shell recently had conventional available, but it seems to have been discontinued in Canada. That was never much of an option, anyhow, since Shell closed many of the bulk suppliers in western Canada, probably due to the overwhelming presence of co-ops and Esso Mobil in this neck of the woods.
