My company has a large mining machine manufactured in China. I'm responsible for the first shipment to Africa. One of the "mechanisms" is lubricated with, what the Chinese are telling me, #40 lubricating oil. They think that it's some type of ISO 68 lube oil. I suggested an ISO 68 gear oil (Shell Omala 68) as I use this elsewhere on the machine. The Chinese say that I don't need to use such an "expensive" oil, but they can't tell me what type to use. They say that any cheap oil will do. The only objects being lubricated inside the mechanism box are splash-lubricated roller bearings. Maximum shaft speed inside the mechanism is 400 RPM. There are no gears and no sliding surfaces, just bearings. What's the cheapest type of oil that I should consider, or can I just use the Omala 68 and be done with the issue?
