I had to reseal my center differential so I had to dump the rotella 85w140 that was only in there for about 10k miles. I decided to go back to a synthetic oil at the specified viscosity of 75w90. I usually buy mobil 1 gear oil but autozone is over 30 minutes away and I was tired so I stopped by the local Napa and grabbed a few quarts of valvoline synthetic 75w90.
I'm not up on my gear oil info but I assume this is decent stuff? Or should I make the drive and get the mobil 1? In this application (land rover discovery) the cats and exhaust pipes pass within inches of the case and it get's pretty hot so I either use a synthetic or a thicker conventional oil and change more often.
