Originally Posted By: ZZman
In the grand scheme of things in a normal street engine which would be most desirable? The little better protection or the fuel economy?
Does a 2.7 HT/HS vary that much from a 3.1 to really matter?
Basically you're talking the difference between a 20wt and a typical 30wt oil. So yes you're going to see 1-2 percent better fuel economy and power. As far as protection is concerned I believe the following quote covers it;
" you want the oil to be as light as possible and as thick as necessary".
