Originally Posted By: CATERHAM
Originally Posted By: Gary Allan
Here's one point you've brought up a few times that I just can't rationalize.
You've stated that you can take any number of lubes and merely take their HTHS to determine their REAL operational viscosity. If that were the case, then VII would be a 100% waste of product. You could merely run without them ..if as you allege they have no effect on operational viscosity.
Where's the missing link in the logic for me?
Gary, thanks for your input.
I've never said VII's have no effect on operational viscosity, quite to the contrary.
Using the simply 10W-30 vs straight 30wt mineral oil example I mentioned. The 10W-30 being basically a 10wt oil with a load of VII polymers in it will of course be lighter than the straight 30wt at cold temperatures. But at 100C if the 10w-30 has just the same kinematic viscosity as the straight 30wt your operational viscosity in an engine will be lower due to the compressable nature of the polymers under stress. To compensate you will have to add more polymers thereby raising the kinematic viscosity of the 10W-30 beyond that of the straight 30wt oil. How much more? Enought to equalize their HTHS viscosities.
Adding VII's to an oil increases both the 100C k'vis spec and the HTHS vis of the oil, they just increase the 100C k'vis spec at a disproportionately higher rate to the HTHS vis.
Can I ask a fairly 'basic' question here?
I thought VII's had very little effect on HT/HS values, because at that level of 'stress', even the best VII's are 'heated/crushed' to nothing, as VII's don't react well to heat. I thought when you got to this level of measurement, you're looking at the strength of the base oil alone?
