Quote:
Anyone have any clue on what I can check or do to repair this further? It doesnt seem to fix anything and it keeps going for well over 3 minutes, in fact it will keep going until I turn it off or turn the motor off.
Quote:
The blend doors are electronically operated/adjusted by the temperature control module. Problems to diagnose are 1)recalibration, 2)blend door actuators, and 3) control module.
I wonder if you are supposed to be able to move the blend doors manually if the actuators/motor (linkage) is working? Earlier, you implied that you applied some force to the doors.
Re-read my original post. Do you have the correct wire plug hooked up to the 3 correct motors? How did the calibration procedure go? Did you figure out how to properly pull the control module codes?
Edit:
Quote:
(4) If the LEDs or graphics continue to flash beyond the two minutes, it indicates that the heater control module has detected a problem and set a diagnostic trouble code. The LEDs or graphics will continue flashing even after the ignition switch is cycled Off and On, until calibration is successful, or until the vehicle has been driven about 8 miles.
Also, I'm not sure, but I think the calibration is supposed to be done with the ignition switch at the "on" position, but, IS THE ENGINE SUPPOSED TO BE RUNNING?
