It's been quite a while since I have been here but I was really hoping to get some input and opinions on the following two OUAs.
The comparison is between the new 3.5L Ecoboost engine and the 3.8L VR38 (GTR) engine. So far it seems that the GTR engine likes to make metal more so than the average V6 but maybe not beyond the 'normal' for other Nissan engines?
So we had to recently upgrade our family hauler to a larger one to accommodate 4 adults and 2 car seats - enter the new 2010 Ford Flex with Ecoboost (TT 3.5L V6 engine) that makes 350hp/355tq with AWD.
It is a pretty nice engine IMHO - high compression (10.0:1) direct injected V6 engine mated to a decent 6 speed auto. I was a bit skeptical of the oil it calls for however which is Motorcraft synthetic blend OR synthetic BUT at only 5w-20. The owners manual suggest an OCI of 7500 miles with either the blend or full synthetic. At first I was going to use full synthetic but with the dealerships the only ones carrying it now (From my research) for $8/qt I figured I would pass also given it has a smaller cST rating @ 100C than the blend by >
So I figure ok I can get the synthetic blend for like $14 / 6 quarts (needs 5.5 qts of oil per change) at Walmart so I will just do a 3000 OCI. That and the oil started to look noticeably darker right around 3000 miles. So I changed the oil and sent it off for analysis and I was honestly shocked and scared a bit at what they found - overall higher metal counts than the GTR has EVER had and IMHO (not very experienced at OUA opinion) the TBN was pretty low at 3000 miles for an oil that Ford recommends running out to 7500 miles.
Anyway here is the first OUA from our 2010 Ford Flex Ecoboost
Versus our GTR latest OUA
comments and thoughts?
