I've begun the restoration of my 1941 John Deere B. I'm looking at this grease for all of the bearings and bushings. The service manual just says high temperature grease. All of the bearings that get greased are tapered roller, low speed (
https://cglapps.chevron.com/msdspds/PDSDetailPage.aspx?docDataId=323084&docFormat=PDF
This is another option that I already have on hand, chosen specifically for a low speed, plain bearing application. I'm not sure the 460 viscosity base oil is ideal for the roller bearings.
https://cglapps.chevron.com/msdspds/PDSDetailPage.aspx?docDataId=77100&docFormat=PDF
What say you all?
Ed
What say you all?
Ed
