Originally Posted By: Dave Sherman
I've changed the ATF in my '08 CR-V twice now, and both times the drain plug had a thin layer of gray slime covering it. Now I'm guessing if there's a magnet there, then it's supposed to collect fine stuff, presumably steel, that doesn't get caught in the filter. So what is that from, mostly? Is it bits and pieces of clutches and whatever the clutches grab, or is it parts of gears and bearings? I changed to Mobil 1 ATF and I'm curious to see if it makes any difference in the amount of stuff on the magnet.
Automatic transmission clutches are multi-plate clutches where there's a stack of disks with friction material (like clutch or brake material except designed to work in oil) mixed every-other-disk with plain steel disks. The steel disks shed very fine particles.
Older automatics also have bands and drums where the band has friction material and the drum is a steel shell, which also sheds.
The gears are hard steel which shed much bigger particles, though not usually as big and "chippy" as rear end gears or manual transmissions. Those get caught in the filter, but sometimes drop off the filter to the bottom of the pan when you shut the engine off. They then can get stuck to the magnet.
Hope this helps!
