There've been complaints about the caliper piston "cutting" through the IMI system on the pad, resulting in brake noise after a short period of time.
Originally Posted By: Nick R
http://www.zeckhausen.com/bedding_in_brakes.htm
Quote:
The brakes may begin to fade after the 7th or 8th near-stop. This fade will stabilize, but not completely go away until the brakes have fully cooled.
A strong smell from the brakes, and even some smoke, is normal.
Thermoquiets are not performance pads. With that bed-in method, you may glaze them. Wagner has a very specific bed-in method:
http://www.centralpartsandsupply.com/specials_flyers/Brake noise & repair.pdf
From page 15, Federal Mogul (Wagner) Troubleshooting guide:
"Disc Pad and Brake Shoe Burnish Procedure
An effective burnish cycle to seat the friction materials into the opposing rotor and drum surfaces requires approximately 200 stops. The 200 stops is consistent with the burnish procedure in the FMVSS 105. As a practical matter for installers, 200 stops probably will not happen since few installers have all day to make that number of stops. Therefore, we recommend the following burnish procedure:
• Make approximately 20 complete stops from 30-mph or 20 “slow downs” from 50-mph to 20-mph with light to moderate pedal pressure
• NO PANIC STOPS
• Allow at least 30 seconds between brake applications for the brake pads or shoes to cool down
• No high speed stops and/or braking under heavy loads that could
result in glazed or otherwise damaged linings Using these guidelines, the friction materials will have conformed to the surface of the rotors and drums for improved stopping performance. In addition, the thermal conditioning of the friction materials during this process will increase the stability of braking effectiveness over a greater range of temperatures compared to when they were first installed."
