We've been using Conoco Megaplex XD-3 on our farm but I see our supplier sells the XD-5 for only an extra 20 cents a tube. We use the XD-3 all over our farm in bucket pins, front end parts, all sorts of u-joints, bushings, etc. Besides the extra 2% moly in the XD-5, the two greases are rated nearly the same as they both have a penetration of 265-295 and a Timken four-ball EP of 400. The XD-5 has a Timken OK load of 60 instead of 55 with the XD-3. The XD-5 has a vis. index of 85 whereas the XD-3 is a 92. How do those numbers relate to each other and would you consider them to be 'good' ratings?
