Looking at an oil filter, it screws onto a kind of spigot or spout coming out of the engine, and has several holes around this threaded portion inside the nitrile gasket that seals to the face of the engine case. I'm assuming during the filtration process, oil shoots out of the spout into the filter, and gets forced back through those surrounding holes into the oil pan? So any trapped dirt and such would be concentrated on the inward facing side of the filtration media? I wonder then, does oil ever pool or concentrate at the top portion of the filter by the outside case long enough for the solution one fellow told me about of sticking a 50 cent magnet to the outside of the oil filter to help grab those metal filings which are magnetic?
