Originally Posted By: c3po
I do not have any experience with Seafoam since I have not used the product, but I have used Pennzoil Platinum and MMO.
Pennzoil Platinum claims to clean 46% of the Sludge on the 1st OCI, and Pennzoil Ultra claims to clean 36% more than Pennzoil Platinum, so 46% times 36% equals 62%, so if my math is correct then Pennzoil Ultra should clean 62% of the Sludge on the 1st OCI.
I have been using Pennzoil Platinum and MMO now for about 10,000 miles, in about 7000 miles of using PP & MMO my Valvetrain was finally cleaned up, since I used both PP & MMO together it is hard to say which one did what.
I would probably give Pennzoil Platinum or Pennzoil Ultra a try for a few OCI's. I would expect that either oil would probably clean everything up inside the engine within about 10,000 miles or so.
This is encouraging to read for me, as its exactly how I`m planning to clean the sludge out of my Toyota. I`m going to stick with standard 3,000 mile oil changes, just to err on the side of more frequent than not frequent enough. I`m also going to send a sample of the first PP & MMO oil change off for a UOA, just to see what the lab comes back with.
This next oil change will be my first use of each product.
-Spyder
