Yeah, Fulton, 18 months is pretty conservative based on this sample but I applaud your cautious methodology.
Some of us have been experimenting with long time intervals and found that, under most circumstances, the time element can be stretched out over couple of years quite easily. The main requirements are regular (not necessarily frequent) longish runs to get it good and hot and that hot run run maintained for a minimum of about 30 minutes (clock starts ticking at full warmup). Environmental and storage conditions can also play a part, e.g. the truck is parked outside in a swamp ( : < ).
I've gone two years on good 'ol mineral oil with a couple of vehicles. This fall, I will sample a three year run on nothing more than Rotella-T 15W40 in a 8300 hour tractor. I will change it for sure this year because it's reached it's hour limit.
For the benefit of those who might have missed it, we should probably hasten to repeat that this truck is WITHOUT DPF and EGR. If both those systems were operational, as with a stock LMM, the OP would have to be much more cautious with long intervals due to potential soot buildup and fuel dilution. Still, that's more a product of miles and regeneration cycles, not time, but it bears watching more closely IMO.
