Originally Posted By: Best F100
I have to qualify my statement for Cateham's behalf:
From an engine durabiltiy and longevity stand point, the higher the better, HT/HS figure. Some manufacturers even recommend going to a 5W30 for their performance engine of the same model (Honda, 2011 Ford Flex with Ecoboost engine), over a 5W20.
From a fuel economy stand point (and engine start up stand point) for a 20 wt oil, a lower cst@ 40C and 100C is better.
kbmag 1, so consequently, I picked Motorcraft 5W20 Full Synthetic
because it had the low viscosity ( 45.9 cst@ 40C, 8.3 cst@ 100C) combined with the higher 2.7 HT/HS figure.
I will add that Kendall 5W20 Full Synthetic w/ Liquid Titanium is rumored to be same product as the Motorcraft (with the addition of Liquid Titanium). All the other product data numbers are identical for both products. Motorcraft 5W20 Blend has a HT/HS of 2.6.
Again, I have to disagree.
A higher HTHS vis is not automatically better in increasing an engine's durability and longevity. If an engine does not require a higher viscosity oil (higher HTHS vis) then there is no advantage in using an oil with a higher HTHS vis spec'.
Very few on BITOG understand the full significance of the HTHS vis spec', it is a lot more than just a measure of an oil's viscosity under stress at 150C. For example:
- It correlates closely with operating viscosity in an engine more so than the kinematic 100C vis spec', even at temps' below 100C.
- Fuel economy of an oil tracks closely with the HTHS vis spec', more so than the 100C k'vis spec'; again at operating temp's commonly below 100C.
