Ok... I can do a lot of things mechanically and I'm very good at it but today tried my patience and I might even have permanent scars on my arm from the experience.
I'm thinking about suing Honda Motor Co...
So here is what happened... My soon to be father-in-law asked me if I could change the oil in his '01 CRV. (First Gen model) and I said no problem.
We went to Canadian Tire to get the filter and oil and all was fine. We put the vehicle up on ramps (because he didn't have a jack) and I proceeded to get to it.
The engine was semi-warm but nothing crazy.
The filter is at the back of the engine above the drive shaft and has a metal bracket-thingy around the filter and it's just to the left of the catalytic converter.
So I give is a good try with my hand and find it's on there super tight.
I tried taking it off with a filter wrench but there is no room and then tried channel lock pliers with no luck.
So then I got the bright idea to run the engine until it was warmer hoping that the heat would loosen things up.
I ran the car for about 15 minutes until the temp. gauge showed normal and then shut it down.
I put my arm back in the filter spot and tried again burning my arm really bad in the process on the catalytic converter.
In a panic and pain from the burn I pulled my arm as quickly as possible and my ring got caught on something and I couldn't get my arm out. Finally I broke it free and pulled out my now badly burned arm.
I fixed up my arm and went back to Canadian Tire to get a Filter Socket Adapter because I had had enough of the filter and it was so badly mangled that the car wasn't driveable in this condition.
We got the filter socket adapter and I attempted the filter removal again but couldn't get it off because it wouldn't fit on the mangled filter so I jammed a rag in-between the filter remover and the filter and managed to get it off like that.
I put the new filter on and snugged it up and drained the oil/refilled.
There was no need for honda to make this so RETARDED and difficult to get to.
Nor was there a need for such a short filter when there is so much room for a much longer filter which could easily be removed with a filter wrench.
They also didn't need to put that stupid bracket around the filter in that very spot.
I'm probably going to have the scar on my arm forever because of some engineers stupidity but I won the fight!
Safe changing out there!!!!
