I've spent the last several days trying to answer this question for myself and would like some input. I currently drive a 2004 Saturn Ion with a manual transmission and 135K miles on it (owned since new). I would like to change the transmission fluid for my own peace of mind since I plan on keeping it until at least 200K miles, maybe even longer. Daily driving is usually 90% highway/10% city. The current fluid is factory filled Dexron III; I bought some Valvoline Maxlife ATF a few days ago, because of cost ($3.50/qt) and their reputation for quality, which says it is spec'd for Dexron VI and earlier. However after further research I realized the viscosity appears to be lower than those fluids which are designed to be Dex III replacements (and not Dex VI). Here are the fluids I have looked at using and their respective viscosities at 40 and 100 degrees centrigrade:
Valvoline Maxlife ATF (Synthetic)
40 degrees - 28.18
100 degrees - 6.11
Valvoline Dex/Merc ATF (Conventional)
40 degrees - 37.1
100 degrees - 7.46
Mobil 1 Synthetic ATF (Synthetic, of course)
40 degrees - 36.3
100 degrees - 7.4
Royal Purple Max ATF (Synthetic)
40 degrees - 35.0
100 degrees - 7.5
My questions are:
1) Should I use one of the higher viscosity ATFs since I have a manual transmission?
2) Are they any other aspects to this I am missing/should be looking at?
Thank you in advance, I've been reading posts on BITOG for the last year and a half which have educated me lots on oils in general. I'm sure the answer would be more clear to me were this an AT in my car, and perhaps I'm just making this more complicated than I should.
40 degrees - 28.18
100 degrees - 6.11
40 degrees - 37.1
100 degrees - 7.46
40 degrees - 36.3
100 degrees - 7.4
40 degrees - 35.0
100 degrees - 7.5
My questions are:
