I see most alot of synthetic oil companys stating that not using a full synthetic oil in a turbocharged engine will cause "oil coking" in turbo after shutdown....this may be the case with different grade gasoline oils, but do you guru's think that petroleum HDEO's suffer from this same problem? I have yet to hear of a turbo related failure on a over the road diesel semi using the very popular rotella t 15w40.
