Best Oil for [censored] Intek 19 HP Mower
by beadvised
6 minutes 24 seconds ago
Purolator Boss 14610
by bbhero
7 minutes 51 seconds ago
Was the original Mobil 1 a Straight 20?
by Gene K
26 minutes 27 seconds ago
Valvoline Maxlife 0w20 Synth blend?
by HKPolice
38 minutes 40 seconds ago
Walmart Canada (GTA) Valvoline MaxLife 0w20 $18.88
by HKPolice
Today at 11:49 AM
Makita B04510 Palm Sander - Fix?
by user52165
Today at 11:41 AM
Red Arrows
by Whitewolf
Today at 11:20 AM
Weber kettle barbecue grill thermometer placement.
by BigD1
Today at 11:19 AM
Gravity Waves: Evidence for Black Holes&Rel.
by MolaKule
Today at 11:07 AM
Car stereo choices
by 007
Today at 11:05 AM
Juicers: anyone have one?
by car51
Today at 10:57 AM
Tips for cooling down a hot car
by mclasser
Today at 10:52 AM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
64 registered (aquariuscsm, AandPDan, AirgunSavant, andyd, 007, 13 invisible), 2129 Guests and 12 Spiders online.
58257 Members
66 Forums
250793 Topics
#1962427 - 07/22/10 06:09 PM 20w50 low temp range?
aub Offline
Loc: Iowa
Can I get away using 20w50 with out doing damage at temps down to 40 degrees Fahrenheit. Reason I ask is I found a 20w50 oil with fair ZDDP numbers.
#1962438 - 07/22/10 06:19 PM Re: 20w50 low temp range? [Re: aub]
rpn453 Offline
Loc: Saskatchewan
Not a problem. The lower limit for a 20W is -4F.
2004 Mazda3 GT Hatch 75k
#1962467 - 07/22/10 06:41 PM Re: 20w50 low temp range? [Re: rpn453]
Eddie Offline
Loc: Florida, Cape Coral
You might want to check the oil manufactures website and look at the product data sheet. You don't say what vehicle/engine but, a 20w50 oil is not usually used in any modern vehicle. I would imagine that start up wear would be bad at temps below 30 or 40F.
CX5 Touring 2.5L :-)
#1962500 - 07/22/10 07:16 PM Re: 20w50 low temp range? [Re: Eddie]
dparm Offline
Loc: Chicago, IL
40 degrees is fine. Is there a reason you want 20w50? You could go for a 15w50 and get a bit more low-temp performance.
2011 BMW M3 sedan ZCP
#1962512 - 07/22/10 07:22 PM Re: 20w50 low temp range? [Re: Eddie]
rpn453 Offline
Loc: Saskatchewan
A 0W at -40F is much thicker, yet most here only run 5W in automotive engines and get good life out of them.
#1962599 - 07/22/10 08:39 PM Re: 20w50 low temp range? [Re: rpn453]
aub Offline
Loc: Iowa
thanks for the info. I will be trying this in an air cooled single cylinder motorcycle. I never ride if its colder than 40F out. Kendall GT1 20w50 it has better ZDDP levels than Yamalube, Suzuki,Kawichem, or Honda GN4 at half the price.
#1962656 - 07/22/10 09:16 PM Re: 20w50 low temp range? [Re: aub]
fuel tanker man Offline
Loc: wytheville, va
maybe so... but there's a lot more to a good oil than gobs of zinc/phos...
...that said, the Kendall is probably at least as good as the cycle branded oils you mention.
Dan
#1962839 - 07/23/10 02:07 AM Re: 20w50 low temp range? [Re: fuel tanker man]
Scooter_man Offline
Loc: Missouri, USA
For an air-cooled single cylinder bike, it's hard to beat Rotella T 15w40. And it's good for as cold as you probably want to ride anyway.
Used it for years (ATVs/Bikes/Scooters/OPE/etc.), never a problem.
Edited by Scooter_man (07/23/10 02:09 AM)
Rob
Member of the 100+ mpg Club!
