I've got M1 in the sump right now and will run it for about the same interval as last just to see if the iron continues to trend up and to monitor the sodium and potassium.
After that I'll try a run on either PP/PU since it seems to be latest craze or I'll just go with RL 5W30. I've been running RL oils in my hot rods for years and years and the UOA's have always looked pretty good - I've just never run it for extended mileage. I did email Dave at RL and he wasn't too worried about my iron numbers.
Rickey,
Thanks for the reference point on your GXP. As noted, I'll probably try something other than the M1 5W30 just to see what it does. With regard to the K&N filters, I know that there are a lot of negative comments about them, but maybe I'm lucky because I've never had an issue with one and I've run them on just about everything. Actually, if you look at my UOA's for the Cobalt, the first one was done on the stock paper filter and the others were with the K&N drop-in. Check out the difference in the silicon numbers...
