Hi Garak,
Originally Posted By: Garak
In the States, G12 is relatively cheap. Up here, it is difficult to come by, even on line. My supplier is currently out of stock, and charges about 50% more than the price you quoted.
Dan is from Illinois, I believe.
G-05 would be a good replacement, I agree. However, getting pure G-05 up here is not easy. One Walmart used to carry it; none of them do except in 50/50. Ford and Chrysler do, of course, but at the cost of over $32 per four litre jug; Walmart was carrying it for about $14 for Zerex G-05. 50/50 is not a suitable option for our climate.
Dan is still not from Canada.
The latest Audi coolants, which are back speced to older models, are essentially dexclones. The Prestone All Makes is essentially a dexclone, too. It is phosphate free, as required by the owner's manual, which, of course, does not require Audi OEM coolant for obvious reasons. It's also silicate free, unlike G-05. Say what you will about dexcool and its clones; however, they are notoriously easy on water pumps. With the Audi having a sealed cooling system, I have few concerns using a dexclone coolant in it. Zerex, for what it's worth, recommends it.
In how far Dex-Cool matches G12, G12 Plus, and G12-Plus Plus is speculation. All these coolants may be similar or even almost identical. Again, even if you can save 50% by buying less expensive coolant, considering how trivial this amount is when compared to the operating and maintenance cost, is it worth the risk?
Zerex's recommendations do correspond to Audi's changing standards. Zerex recommends G-05 for the older ones (like mine). For the newer ones, they recommend dexcool. Those happen to be the ones that call for the newer Pentosin fluids. Since Audi back speced the older models for the newer fluids, it's a safe assumption that the dexcool or its clones will also work.
I do not find the expression "safe assumption" very confidence aspiring!
With respect to the timing belt, it's not that expensive of a job. I get the part for $20 and do it myself.
You need the timing belt, the accessory belt, the thermostat, a couple of idle roller and a belt tensioner, RTV sealant, and coolant. The parts alone are $200 to $250. If you have the TB service performed at a shop, you are in for 8-12 hours labor at $85 to $140 per hour labor. Do you replace really only the timing belt?
As for Pentosin, I'd gladly use it if it were reasonably available.
I don't know about Dan, but I can find Pentosin at my local 76 gas station.
Dexcool and the like meet the requirements.
What exactly are those requirements? I only know VW and Audi require part number XXXXXX.
I'm simply not going to spend double the price to have a Pentosin label on a bottle of dexcool, just like I'm not going to spend double the price to have a Motorcraft or Mopar label on a what is actually a bottle of Zerex G-05 (since Zerex supplies it to both companies).
The Pentosin products I buy are "Made in Germany." Does Zerex produce in Germany?
It's not about busting one's budget; it's about spending sensibly.
I consider buying the OEM parts and supplies for a $40k vehicle sensible. The additional cost of OEM coolant is certainly marginal, as I have already explained.
Most parts I get are OEM and from a reputable, cheap supplier. I can get Mahle, Mann, and Bosch oil filters for under $5 a piece. I use Pentosin steering fluid, since there are few appropriate alternatives (other than Bilstein fluid). I am not, however, going to be going on a wild goose chase to obtain Pentosin engine oil or Pentosin antifreeze when other equally suitable alternatives are available.
You are certainly at liberty to do whatever you want to your vehicle.
Secondly, if someone has an emergency, the Pentosin may not be available. Dexcool will be.
Let us hope the Dex-Cool will not cause the emergency.
Cheers,
-J
