I have been a long time lurker on this site and decided to finally sign up and start adding something positive to this community and really expand my knowledge of oil beyond the basics.
The car is stock and runs with an OEM Toyota oil filter which is changed every oil change and a TRD air filter (which will probably be reverted back to a paper filter soon for better filtration). I purchased the car used about 2.5 years ago at 77K and have done OCI at every 5K. I know from the service log that this car previously had all of its maintenance done on time with a dealer. I do all my own maintenance and I have always used the Toyota OEM oil filter but as for oil I started with synthetic blends and moved to full synthetics at 95K. I didn't know about the difference between oils until recently, my last oil change before the GC was Mobil 1 5W-30 and I replaced the GC with Lubro Moly 5W-40. The GC has been in my car for about 3 months now.
I sent this batch of oil in mainly because I started hearing a slight ticking noise from my engine and wanted to see if it was my rod bearings that had gone (this happens to a decent amount of MR2 owners so I wanted to be more sure if it was this or not). I was relieved to see that my engine is good shape.
