Buddy asks me to fix his daughter's AC which is blowing hot air. He says AC has gotten weaker every year for the last 4-5 years and now is finally kaput. I can't see any evidence of a refrigerant leak although I didn't bother to look at the evaporator (way too much work). I checked the static pressure. Not enough to move my gage. When I opened the hi and low side there was enough to cause a little puff. I then pulled a vacuum with my 2 stage oil vac pump. System pumped down to full vac. I turned off the pump and waited 15 minutes. System held full vac. Based on everything I have told you, I figured the system did leak very slowly over time. Therefore, I am ASSUMING that the original amount of compressor oil is still in the system and suggested to my friend we recharge with 134a only and do not add oil. I restarted my vac pump and ran it for another 30 minutes and then measured in 30 oz of 134a according to the owners manual.
Did I do the right thing by not adding oil?
If a system holds full vac, does that mean there is a good chance that it will hold at operating pressure? Thanks for your input.
