Originally Posted By: Mike_dup1
Most auto oils now have lower zinc and phosphorus (high pressure) additives in their oils. This was done to increase catalytic converter life in automobiles. Most "motorcycle" oils have a much greater percentage of high pressure additives in their oil for this reason.
In order to comply with new standards intended to avoid damage to catalytic converters, oil blenders were compelled to reformulate their additive packages using less of the cheap and effective ZDDP, and more of better, but more expensive, additives.
However, they found they can still produce the older, cheaper, formulations and sell that oil at a vastly higher price as 'motorcycle oil' to the gullible.
