Hello, I need to ask for some information regarding these tests for grease properties:
Timken OK Load ASTM D 2509 lb
4 Ball Load Wear Index ASTM D 2596 kgf
I have 2 greases at home; one has a Timken OK load of 80
but the 4 Ball LWI is 50, and the other grease the Timken OK Load is 65 but the 4 Ball LWI is 65, which is higher than the first grease. It seems the relationship between the 2 tests is not directly proportional ? Any advise is appreciated, thanks again.
