Originally Posted By: Lurch
Now I'm confused again.
In a nutshell Lurch, Delvac does not seem to be the most robust HDEO oil when it comes to shearing. Rotella T and ST seem to hold viscocity longer than Delvac.
That said Delvac is still a good value in oil for your bike and would most likely still out perform many "motocycle" specific oils.
Stick with 2-3k oil changes on your bike using dino HDEO's and you will be fine.
Even the best oils eventualy get thrashed in a shared sump bike. Buy cheap (HDEO) and change often (3k and under).
If you really want to push your OCI out longer run a $13/qt ester based syn like Maxima or Motul.
