2005 Suburban with automatic climate control and front/rear AC's. The rear AC worked but the front blower stopped. The dash control worked but the blower would not come on.
The passenger side footwell black plastic shroud was removed with a 7mm socket. I then tested the AC Blower Power Module. it was receiving power but was not outputing the ground to the blower. It can be removed with a 5.5 mm socket. The heat sink is actually mounted into the intake duct to help cool it.
If it was working correctly the heat sink becomes very hot. When broken it does not turn warm at all.
I replaced it with a OEM AC Delco unit for $70. works like a champ now.
If you hae a similar problem with the blower, check out the Blower Power Module.
