So I have a 2001 Mitsubishi Eclipse GT (3.0L 6cyl). I got the car at 93,000 miles, no idea really on how well the previous owner(s) kept up the oil changes. It's currently at 120,000 miles. It has seen 2 or 3 OC's (cant remember) with 5w30 PP + Lucas oil stabilizer + PureOne filter. Currently has 5w30 Castrol Edge + PureOne with 5,900 on it so far. Loses about 1/2qt/5,000 miles and is maintained religiously.
The oil appears to be very clean for the amount of miles it has on it, this picture was taken at around 5,000 miles.
I dropped the oil pan and found this. There was a thin layer of sludge in the bottom of the pan, and a few slightly larger "clumps" of it that are visible if you look towards the top and bottom of the pan in the picture. I cleaned the sludge out and put it back on the car. Is this an acceptable/normal amount of sludge for a car with 120,000 miles on it? If not, what is?
On the inside of the crankcase I also found this. If you look on the left you can see small black spots which is sludge. Same question as above with the acceptable/normal amounts of sludge...
Now onto the top end of the engine:
Removed the valve cover and this is what I found. Everything seemed very clean, no sludge at all, just a brown varnish.
Now, I want to rid my engine of any and all sludge at all, because I intend on running this car into the ground, and the engine is the #1 thing to worry about in my mind.
I was thinking about doing an MMO treatment, however here are my concerns:
#1. After seeing these pictures and reading the info, is there even a point in trying the MMO in an engine that seems pretty clean already?
#2. MMO thins out the oil a bit, and the Ky heat + my spirited driving tell me that a thinner oil isnt a good thing here.
#3. I plan on using the Pennzoil Ultra oil for my next OC, and I would like to use it for 1 year/15,000 miles or whichever comes first. If I use the MMO now will I have any problems doing an extended OCI next or would it be best to do a shorter OCI afterwards to "flush" out any remaining MMO+sludge? I don't want to waste my precious Pennzoil Ultra nectar of life, or money for that matter.
#4. How much MMO would you guys recommend given my spirited driving/daily heat/sludge buildup, and for how long?
#5. I know now, after reading a lot on BITOG that the Lucas oil stabilizer is junk and not highly regarded, is there a chance that it made more sludge in the 20,000 miles that I ran it? I never really had any problems with it.
Thanks!
Thanks!
