FIL gave us an older Jacobson hydrostatic rider...14HP Kohler. I'm going to guess its probably a 70-ish model?
He used it a couple years ago, and its sat for about three years (since I last got it running). About a year ago, it "leaked" gas and caused a stink in their garage, then obviously the gas dried up. He wants it gone, and we just bought a house with about 2.5 acres of grass.
Obviously the battery is toast, as is the solenoid or the switch (or both). I got it to turn over by jumpering across the starter. I did pull the bowl off to find "gas"...it was more varnish than gas, but it was at least still wet. It has a brass float. I dumped that and put fresh gas in the tank. After about 5 minutes, gas started dripping from the carb, out the air horn (for lack of a better term). It appears as though the carb is filling up with gas, then dripping out the carb into the air cleaner.
I did not get it to fire, although I didn't really work at it very long. Any ideas on the carb leak? Needle went bad? Float bad?
I'm not hurting for a lawn mower, this one will just make life a little easier for the wife to mow...still have my Commercial 10A to chase around until we get this rider fixed.
