Whatever you end up doing be aware that the 5.7L engines with MDS usually sound HORRIBLE with aftermarket exhaust as a rule.
Oh yeah, it would probably sound like an old beater that is badly in need of a tune up. Maybe there is a way to defeat MDS? Pull a fuse?
1 - Easiest way is to press the Tow/Haul button and it shuts it off. Doing that though changes the shift pattern. You end up holding your gear much longer which means you get longer more drawn out shifts which hurts MPG.
2 - You can buy a tuner( Hypertech, Diablo, Superchips, etc... )and disable it using the tuner( when offered )but not everyone wants to go that route. As I understand it you can't JUST use the tuner to shut off MDS. You still have to install the tune which is a warranty issue for many folks. I would love to see a handheld tuner that JUST disable MDS or that will let you select the range it works in. MDS is fine in my truck at 40-45MPH+ but anything under that and it is horrid.
3 - Unplug the MDS harness at the back of the engine so the solenoids do not work. I guess when it is unplugged it creates some kind of fault that keeps the PCM from turning MDS on( built in safety catch I assume ). The draw back to that is you get a SEL light.
Unfortunately there is no fuse or relay you can unplug( not on 06-08 models anyway - not 100% sure if 09+ changed ).
