hello I am trying to find any information on mixing methanol and gas in a 50/50 mix .. it is for a drag car and is not for the street .. the only research I have found was on small amounts of methanol added to gas as a octane booster but the mix was only less than 5% methanol and also had additives with it .
and on the other end of the spectrum M85 was 85% methanol and 15% gas .. I have not found much on what additives would be needed to make sure the 50/50 mix will stay mixed ..( acetone ) has been one mentioned because it is a solvent from what I understand ..
