Getting pretty frustrated after re-mounting my mirrow four times in the past year or so. (The mirror comes off right after you adjust it. Happened again today.) Problem seems to be that I'm getting poor glue coverage on the little button that adheres to the windshield. When I looked at it today, glue had only covered about 60% of the button outline. 40% was bare as could be.
When I mounted it last time, I pushed HARD on the thing for a good 2 minutes. Then I let it sit overnight for two nights to cure. Even used the high-end Permatex glue. Did the initial mount at 75 degrees outside, which is right at the top end of the temperature range listed on the package.
I'm wondering if I'm pushing TOO hard on it when I'm mounting it and the glue is spreading out too much. Or, it seems like the window may have a slight curve in it there so as not to allow even coverage. Those are the only things I can think of. This last time, it wasn't up for more than a 4 weeks.
I'd be willing to go the dealership to have it done, but I'm not convicned anyone can make this sucker stay put!
Anyone else had this problem?
