My motorsports club is holding a lapping day in August at the Mosport Driver Development track. I imagine the configuration we'll use will be slow (maybe 50-60mph average for my Neon?)
I've got a 3spd auto and can keep it in 1st, or 2nd which uses 1st and 2nd, or D. 1st is good for 50mph and 2nd to about 75mph so I might only need 3rd once a lap.
My plan is to manually shift the trans to avoid the double downshift on slow corners.
Anything I should watch for with the trans? What's the first sign its overheating? It has lines to the radiator so it has some cooling.
Any tips for my first track day? The AC isn't working so I was thinking of putting a switch on that fan to run manually, probably all the time out there.
