Any of you british car guys know anything about this?
Its the 1500 engine. It appears that theres oil getting to the head because the valves are wet. however, when I took out the filter, it looked like it was bone dry...as in, hadn't seen oil.
The gauge shows good pressure, so its not a pump issue.
the only thing I could think of, was that the adapter that was added so the car would accept regular Napa oil filters may not be allowing oil to the filter.
Any thoughts? I'm a bit spooked.
