jayno20
Thread starter
how do you tell what it is rated?
The API® Service Symbol and Certification Mark will be on the bottle.quote:
quote:
Originally posted by 427Z06:
The only FACT that's well documented here is that SOME people perceive a difference, NOT that it is actually quieter. Further, it has yet to be established that this perceived difference in any way effects the wear in an engine.quote:
Originally posted by Dominik:
A lot of engines will run a bit quieter on say one type of 10W-30 oil a opposed to onother 10W-30 this fact is well documented here on this forum...
Great, a food Nazi. Kinda ironic with the flag waving a saluting symbol but you advocate taking away freedom of choice.quote:
Originally posted by hominid7:
.......I think McDonalds is doing us more harm than RJReynolds. We should have a "fast food sin tax".[/QB]
If this engine is really prone to this, thick diesel oil isn't the best solution. A good cleaning with AutoRX, followed by the manufacturer's recommended viscosity grade/OCI in the latest service category would be best.quote:
Originally posted by Master ACiD:
i have the same engine. this mitsxubishi 2.5 v6 engine is prone to hydraulic lash adjusters sticking and making noise...
There's nothing special in HDEOs (diesel oil) that is going to clean anything. It's forte is to keep contaminants (especially soot) in suspension. Ask anyone who has tried to clean up sludged engine using HDEOs. AutoRX is the best at cleaning engine internals safely. If you don't want to use AutoRX, you can always pull the lifters and use the Mitsubishi recommended procedure for cleaning the lifters (lash adjusters).quote:
diesel oil has worked for me. when i got the car it has atleast 1 stuck lifter. after a few thousand on diesel oil the ticking went away.
also on dodge/mitsubishi forums, its a common thing to use diesel oil to prevent this.
Originally posted by BrianWC:
[QB] Amen. Last I recall, someone actually placed some type of audio meter and found no difference. Of course he was instantly criticized by all the armchair audiologists out there.
Geez read my post again if you can't detect more start up noisse with heavy oil as opposed that light stuff then I respect your point of view.
And get that audiologist to calibrate his equipment.
Must you guys use every opportunity to further you thinner is better agenda.
Since you're recommending something other than what's recommended by the manufactuer, I believe the shoe is on the other foot.quote:
no doubt, thats why i recomended a 5w40 for winter use. i guess you didnt read my entire post before commenting on it though.quote:
Originally posted by TallPaul:
15w40 is probably too thick for winter use.
Different engine design, and the 2.5 owner hasn't mentioned excessive oil consumption.quote:
Originally posted by Intrepid:
On my 99 2.7 Intrepid w/ 73,000 miles, I would burn a quart of oil every thousand miles. I run 10w30 M1 with a PureOne filter & I have the quietest engine I've ever heard.
So I poured in a quart of 15w50 M1, and so far no oil consumption plus I haven't lost any power.
Hootbro: I used to feel the same way as you but I've begun to think about it differently especially after I read that McDonalds cooks its food much healthier in certain other countries than in the home market. Here in America McD's is full of trans-fats where in many European countries the same items have none because healthier cooking oils etc...are used.quote:
Originally posted by Hootbro:
.......I think McDonalds is doing us more harm than RJReynolds. We should have a "fast food sin tax".Great, a food Nazi. Kinda ironic with the flag waving a saluting symbol but you advocate taking away freedom of choice.
Hootbro [/QB]
