Half Price GTX 15W-40 @ REPCO in Oz
by SR5
05/27/16 03:27 AM
1991 Sierra rear brake squeel
by sr17
05/27/16 12:57 AM
2015 Silverado Diff Fluid Change
by Realtech214
05/27/16 12:25 AM
Undercarriage Rust Management
by OpenClose
05/26/16 11:31 PM
New used tires
by gfh77665
05/26/16 11:29 PM
Hybrid and ROI (Return Of Invesment)
by HTSS_TR
05/26/16 11:14 PM
Best Walmart stocked wiper blades?
by aquariuscsm
05/26/16 10:54 PM
What Ohm antenna wire to use?
by daves66nova
05/26/16 10:46 PM
Turtle Wax Passed The Test
by RevRider
05/26/16 10:46 PM
Total FLUIDMATIC G6 SYN ATF, 13.7k mi OCI, 34k mi
by Emperors6
05/26/16 10:17 PM
Honda NC700X Red Line 10W30, ~5,000 miles
by bulwnkl
05/26/16 10:13 PM
If you liked the Fram AirHog Filters
by rrounds
05/26/16 10:07 PM
Timmytimmy, Peakboy91, TimingBeltKing, watergate528, iamtheanimal
57996 Registered Users
22 registered (cobra7279, bbhero, chrisri, Bandito440, 3 invisible), 474 Guests and 331 Spiders online.
57996 Members
66 Forums
249469 Topics
#1903651 - 05/26/10 05:36 PM Mercruiser 454 castrol gtx 20w50 sodium level
steve111 Offline
Loc: seattle
Have dual 454's that have 100 hours in last eight years. One is fine, the other had high:
iron 240 (26) (after oil and filter change and 12 hours)
lead 37 (4)
copper 65 (11)
Alum 34 (4)
sodium 498 (98)
Seems like sodium is still high, press test of coolant system is okay. Any idea's?
#1903677 - 05/26/10 06:10 PM Re: Mercruiser 454 castrol gtx 20w50 sodium level [Re: steve111]
Steve S Offline
Loc: East of IGO
What does the rest of the uoa look like?
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#1903678 - 05/26/10 06:11 PM Re: Mercruiser 454 castrol gtx 20w50 sodium level [Re: steve111]
Pete591 Offline
Loc: Michigan
I use M-1 20W-50 V-Twin in my Mercruiser 525 EFI's.
Gorilla juice...practically 0 wear numbers in oil samples,
What you have is not probably oil related. One engine is abnormally wearing...spelling possible failure in my books out in the middle of the lake...needs to be overhauled.
#1903827 - 05/26/10 08:12 PM Re: Mercruiser 454 castrol gtx 20w50 sodium level [Re: Pete591]
Chris142 Offline
Loc: apple valley, ca
Do these use lake water as coolant or do they have their own radiators?
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#1904111 - 05/26/10 11:30 PM Re: Mercruiser 454 castrol gtx 20w50 sodium level [Re: Chris142]
Gary Allan Offline
Loc: Pottstown, PA
Did a piece of fiberglass batting/sound deadening get sucked into the one engine?
http://lube-direct.com/gallan/
#1904277 - 05/27/10 07:51 AM Re: Mercruiser 454 castrol gtx 20w50 sodium level [Re: Gary Allan]
addyguy Offline
Loc: Canada
GTX uses sodium as an detergent/dispersant additive, so that is some of it.......
2010 Kia Soul 2U - 2.0L I-4, auto, 85k miles.
QSGB 5W-20, NAPA select filter(?)
#1904312 - 05/27/10 08:16 AM Re: Mercruiser 454 castrol gtx 20w50 sodium level [Re: Chris142]
cchase Offline
Loc: New England
This is closed cooling... you can't pressure test a raw water cooling system.
#1904741 - 05/27/10 02:42 PM Re: Mercruiser 454 castrol gtx 20w50 sodium level [Re: cchase]
Chris142 Offline
Sure you can. Just plug up the holes. Thats what we done with my Boss's boat to find a leak.
87 F250 delo 15w40
Z400 Lucas 10w30
KLR250 Maxima 10w40
#1904813 - 05/27/10 03:50 PM Re: Mercruiser 454 castrol gtx 20w50 sodium level [Re: Chris142]
cchase Offline
Loc: New England
Is this run in freshwater or saltwater?
#1909903 - 06/01/10 04:51 PM Re: Mercruiser 454 castrol gtx 20w50 sodium level [Re: steve111]
steve111 Offline
Loc: seattle
Chrom<1
tin,1
nickel<1
silver<1
magnes 168
calcium 2228
barium<1
phosperous 759
zinc812
moly<1
boron 18
#1909910 - 06/01/10 05:00 PM Re: Mercruiser 454 castrol gtx 20w50 sodium level [Re: steve111]
steve111 Offline
Loc: seattle
The boat had very little use the last 8 years, mostly sitting. An oil analysis was done and came back with a coolant leak on just one engine. Changed oil on both engines and ran for 12 hours, but sodium came back as an alert to be checked at next oil change on just the one engine that had the high #'s.
Maybe residue? And coolant was just seepage from sitting so long?
Boat used in salt water, freshwater cooling. Pressure tested the closed system, okay!
Both engines had the oil changed, only one had the high #'s. No other symptems, good oil pressure, full rpm's, full power, starts easily etc.
#1912327 - 06/03/10 08:23 PM Re: Mercruiser 454 castrol gtx 20w50 sodium level [Re: steve111]
Steve S Offline
Loc: East of IGO
Do the engines have oil coolers?
#1913055 - 06/04/10 01:36 PM Re: Mercruiser 454 castrol gtx 20w50 sodium level [Re: Steve S]
SteveSRT8 Offline
Loc: Sunny Florida
you must have HUGE clearances in those motors to run 20w-50. Sounds like one is getting even bigger.
I'd want to pull it down for a look see. Good luck with it.
I have a custom tweaked zz572 crate motor with a blower and it uses 0w-30 Amsoil synthetic. About 850 hp at the crank.
Never uses oil and gets great analysis #'s.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
