Yeah I said the same thing about it being critical to engine function but nope. 210 quote on the repair. I'm trying to find the warranty book as I read the snipped on GM page and it doesn't mention the cooling system.
This is all I can find on it:
Quote:
In addition to the Vehicle Coverage described above, General Motors will warrant each 2010 through 2005 model year passenger car, light duty truck or van for 5 years, or 100,000 miles/160,000 kilometers with no deductible, whichever comes first, from the original in-service date of the vehicle, for warrantable repairs which are required as a result of defects due to material and/or workmanship to the Powertrain components as listed below:
Engine
Cylinder head, block, timing gears, timing chain, timing cover, oil pump/oil pump housing, OHC carriers, valve covers, oil pan, seals, gaskets, turbocharger, supercharger and all internal lubricated parts as well as manifolds, flywheel, water pump, harmonic balancer and engine mount. Timing belts are covered until the first scheduled maintenance interval.
Transmission/Transaxle/Transfer Case
Case, all internal lubricated parts, torque converter, transfer case, transmission/transaxle mounts, seals, and gaskets.
Drive Systems
Final drive housing, all internal lubricated parts, axle shafts and bearings, constant velocity joints, axle housing, propeller shafts, universal joints, wheel bearings, locking hubs, front differential actuator, supports, front and rear hub bearings, seals and gaskets.
What Is Not Covered
All the above items are not covered for damage due to accident, misuse, alteration, insufficient or improper maintenance, contaminated or poor quality fuel. Medium Duty trucks, including the C4500, are excluded from this Powertrain coverage.
Roadside Assistance Program
General Motors is proud to offer the response, security, and convenience of the 24-hour Roadside Assistance and Courtesy Transportation Program for a period of 5 years or 100,000 miles/160,000 kilometers, whichever comes first (based on original in-service date).
Refer to your Owners Manual for details, or consult your dealer/retailer.
For 2010 through 2005 model year passenger car, light duty truck and van owners requiring a more comprehensive coverage than what is provided with this warranty and the New Vehicle Limited Warranty, an authorized GM service contract (GM Protection Plan) is available through your dealer/retailer. These are the only plans recommended by General Motors. See your dealer/retailer for details.
