Originally Posted By: rjacket
I know you're sending in for a VOA but the link to the spec sheet is confusing. Did you call their tech line for clarification?
See, the pour point is listed as a value of -29c / 20f, whereas other stats are in quite wide ranges or as a minimum.
So why is pour point a value rather than a range? Is it because the others could actually be anywhere within the range they show? And that is because their syn is bottled by different suppliers?
Bill was concerned with the numbers, and the pour point is not great for a full synthetic. MC syn blend has a pp of -45c.
So again, the VOA will be interesting because the deal runs until the end of June now!
Yea, I don't think those things in the tech info are actual specs on the oil, they just put the API characteristics on them. For example the viscosity range for the 5w30 is listed as 9.3-12.49. Well duh no kidding! I would hope it was in the 30 range.
VOA will be interesting!
