I am currently rebuilding a 2005 Suzuki RM-Z 450 from the ground up. Lots of damage from the PO due to his ignorance, most of which stems from never changing the oil (or so it looks). The nail in the coffin was a manual cam chain adjuster that never saw an adjustment allowing the cam to jump causing the intake valves to get intimate with the piston.
I'm assembling a new head complete with a new valve train, new cams, new crank, new piston, replated cylinder, and all new bearings...most everything will be new.
The valve train is a flat tappet "cam-on-bucket" configuration (attached photos gives you a great visual). This is a shared sump bike with a max capacity of 1500mL.
I'm looking for opinions/recommendations for assembly lube and break-in oil for this beast. I'm about to start putting this thing together and thought I'd inquire to see what others were using.
Also, any thoughts on the CJ-4 spec Mobil 1300 Super 15W40? It's been hard finding a recent VOA/UOA to go off of and I bought 5 gallons a few weeks back for $6/gal. I figured for the cost I could afford to change it often enough even if it wasn't that great.
Any other comments or info requests are welcome, thanks in advance.
