Hi all, I was hoping some of you experts out there can shed some light on a concern I've had. Here's my scenerio:
I have Subaru equipped with a manual transmission with full time AWD. The front and rear differentials are open while the center differential is viscous coupling (standard Subaru setup). I've noticed the temporary spare tire has about a 1" smaller diameter than the full size tires. I was wondering if using the spare tire will cause premature wear to the center diff? My thinking for why Subaru would equip theirs vehicles with a smaller sized spare is that having an open diff would prevent excessive wear to the center diff. Does this logic make sense? My fear is that I have to use the spare when I am 100 miles away from civilization and end up causing expensive damage to the drivetrain, all because of a flat tire.
OEM tire size: 225/45-17 (24.97" diam)
OEM spare tire size: T125/70-17 (23.89" diam)
Should I not lose sleep over this or should I consider purchasing a larger spare tire for an added margin of safety?
Thanks!!
Thanks!!
