It's thick and gooey, but it works VERY well. You can use it everywhere on the system. It won't react with brake fluid either. So when I rebuilt a master cylinder I used it on the rubber parts and no ill effects. I lube up the caliper pistons, rubber seals, and the pistons move much easier, which in turn has a noticable effect on the brake pedal effort and feed back.
