I wanted to sharpen the blades on my Dad's Cub Cadet Tractor.
I tried using a half inch ratchet, no luck.
I tried a Breaker Bar, no luck.
I do have an air impact wrench, but I will probably have to take the deck off.
I tried spraying some WD-40 on the bolts and I even had a 2X4 piece of wood blocking the blades, every other mower I have worked on has been no problem getting the blades off, anyone run into this same problem.
