From the manufactures manual (B&S) loss of power, and oil consumption can be caused by using a multi-weight oil during summer/warmer weather. Also I have seen the inside of air cooled engines that were run on multi weight oils, and synthetic at that with thick heavy varnish areas. I assume the multi weight oil burns off easier or during the engine warm up period, it may also shear easier ? I really don't have all the answers, however I do know my air cooled engines ( I have several old cast iron Kohlers, B&S etc) call for straight weight oils I run either Delo 400 or Rotella straight 30 in these engines even during winter months.
