- Joined
- Jul 2, 2007
- Messages
- 5,294
Wheel alignment spec sheet interpretation sought... alignment gurus requested
The specs in the actual column may be okay, I just want to make sure since I am not up on wheel alignment stuff.
I'm concerned about the fact that Front Left and Front Right Caster remain out of spec (asterisk next to the figure in 'actual' column) after the job was completed, as well as Rear: Total Toe also out of spec upon completion. This is assuming that the figures in the "Actual" column are final adjusted figures.
This is from a Hunter Hawkeye alignment rack operated by a local tire shop (regional chain store) on the wife's 2005 VW Beetle TDI. She took it in and waited, and brought me this printout along with the receipt.
