Originally Posted By: d00df00d
As I understand:
1. Oil pressure is low. This means there is a minimal film on certain critical moving parts.
2. Coolant is circulating slowly. This means the cooling system is not as effective.
3. Combustion is not very efficient. This means there is more contamination generated that might end up in the oil.
4. Since the engine doesn't spend as much time at operating temps, any contamination (e.g. fuel, by-products, water condensation) that does get into the oil doesn't have a chance to "cook off."
This is all because average RPMs are low and a lot of time is spent at or near idle.
Synthetics usually hold films better, survive heat better, and deal with contamination better (i.e. without breaking down or losing performance in any of those conditions). On the other hand, a modern conventional should work just fine in a modern engine, provided it is up to the required spec and is changed at the right intervals.
1. Why would you want a high oil pressure when the engine is at idle? There is nho load.
2. Same as above, at idle the engine produces the least amount of heat.
3. That was true with carburators, but with fuel injection and computer control, once the engine goes into the closed loop operation, there is always the right amount of fuel delivered to keep the combustion optimal.
4. All stop and go driving doesn't automatically equal short trips. Since I move my commute is 100% city, but it still takes about 30 minutes, how is it different from 30 mins of highway driving?
In general, I think very short trips are worst coupled with cold climate. If your commute is about 30 or more minutes, it doesn't really matter if it is city or highway, unless you redline the car every stop light
